So I've read the stickies but still can't figure out whether or not HID's are illegal in aftermarket housings. So, if not, where can I find HID lights w/ new housings for a 09' Focus Coupe?
No, most Focus aftermarket headlamps are Halogen Housings meaning Xenon HIDs are illegal in them. You'd have to do a retrofit on the headlamps and put in Xenon HID Projectors for proper HIDs.
HID's are "illegal" in any housing not specifically designed to use HID bulbs.
You need to check to see what your aftermarket housing is designed to accept. They should be able to tell you in the manufacturer's specifications or instructions.
I'm not sure if there are any plug and play aftermarket HID housings for an 09, but Unique Coatings offer a conversion service, that will give you a proper HID headlight.
By DOT regulations, HIDs are illegal in any car not equipped from factory regardless of what kind of housing you're using even if it is a proper retrofit. You'll be fine doing a retro fit though. I'm pretty sure no one has ever gotten hassled for aftermarket HIDs unless they're in stock housings.
It just depends on who ur talking to on here. I have Hids in my headlights and fogs and havent had any problems with them at all either with police or anyone. They are really bright and light up the road really well and all in my stock housings. No one likes them on here so just do what u want.
^No one on here cares if you do HIDs right. By that I mean you get the proper projectors for them. If you do them half-assed and put them in stock lights they not only blind others on the road, they look stupid. Every time I see a car with HIDs in non-projector headlights I laugh because it's pure rice.
My vent selector and temperature selector are really stiff in the summer time. It's been like this for a few years. Works fine in the winter.
Well this morning it was stuck on defrost and I tried to switch it to face. It wouldn't move. I guess I forced it too hard and I think it broke. The...
Hi can anyone help I've just bought a focus 1.8 sport diesel tdci. Over all happy with the car but the previous owner has put a straight through exhaust on it, every time you start the car and drive all you can smell in the car are diesel fumes any suggestions would be great
The battery light comes on with ignition on and turns off when the engine is started but the battery is not charging and the battery drains down. After charging manually, voltage is about 12.8v. With the engine running , the voltage does not increase ( should be around 13-14v), I have...
104,000 miles on it.
I added a switch above the cigarette lighter to turn it off when I get out of the car, and replaced the cigarette lighter because it didn’t work.
What do I do now? I’m assuming I need to replace the stock plugs, I’m planning on doing it Friday and replacing them with...
Hey guys, I've got a little issue with the blower motor in my zx3 hatch. I've replaced the blower motor resistor and I'm still popping my fuse in the box under the hood. The car did sit for about 2 months and the blower had worked before it was parked. I'm stumped. Could the blower motor itself...
