1 - 4 of 4 Posts
Ok, my 2001 ZX3 has a left rear stop light problem and turn signal problem. I have checked the wire that powers the turn/stop section of the bulb and it has 1.5V on-off with the relay I need 11-13. the left tail light works and the front left turn and running light works. The car had led 3157's installed when I bought it and was Pretty sure they worked befor now they dont and I replaced the led with a incandescent. no joy!! [:)][:)][:)][:)][:)][:)]**also the the third brake light is out no power at all when you step on brake also no voltage what so ever on the tail/turn circuit when you press on the brake.
Is this the Hazards Relay Box Switch ETC?
I saw in a nother thread where this happened everything appears ok. I ve also checked the wire front to back it al looks ok. the 1.5v is what is killing me? and then 0v when the brake is actuated? I could be driving a XJS if I wanted to be an electricion!
1 - 4 of 4 Posts
