One of the last times under my car (2006 ZXW auto transmission) I noticed that the rear of the transaxle right under the axle seals was a bit wet (when pretty much the rest of the underside of the engine is nice and dry as can be at least). I am assuming it is the axle seals one or both of them that is leaking, but could it also be the rear/lower engine mount leaking (is it a hydraulic mount even?)
But if it is indeed one or both of the axle seals leaking, I know I have to pull the inner CVs out of it and am familiar with the process (thanks to the service manual), but it calls for a special 307-572 tool to insert the new seal into the transaxle. Instead of using that tool should a tool like http://www.harborfreight.com/10-piece-bearing-race-and-seal-driver-set-95853.html work just as well as the official tool? Also what would be the best way to remove the seals themselves?
