No tune, no fuse switch!
I swapped my TCS/ABS unit for just a plain ABS unit that I pulled from a 2003 wagon at a local salvage yard. I drove it around for a week with no I'll effects. I did some research and cross referencing I everything lead me to believe that there isn't any difference in ABS control modules between SVT, drum brakes, and etc. I installed it right on my existing hydraulic pump and I didn't even remove the lines, I will admit it was tight space to work in.
The TCS light is completely gone like it was never optioned... if I pull the fuse, push the button, turn the key on, or spin the wheels the icon doesn't light or flicker; and the timing portion of the TCS is gone also. The ABS works too of course; not bad for $20 and an hour of time. If you can pick one up for cheap it might be the way to go.
ABS
TCS
TCS ---- ABS
ABS
TCS
TCS ---- ABS
