i have a 2004 zx3 and last night i ran into the dreaded key wont turn problem. after some quick googling i think i know what causes it, so my question is.. whats the cheapest, effective way to fix it?
Please note. If you do not have 2 pats keys and your car at dealer they cannot match up the cylinder.. When I tried to have a new cylinder matched to my key they said nope. You need 2 pats keys or we need to replace the entire thing with new keys.. Made me quite sad.You might be able to get it to turn again by spraying WD40 inside the lock cylinder and tapping on the key with a hammer. Before you try that, go purchase a new lock cylinder from the Ford dealer, and have it keyed to your spare key. When the key turns, leave it in the ACC position. We have directions on here for changing the lock cylinder when the key turns, and when the key won't turn. If the key will turn one last time, then swapping the lock cylinder will take less than an hour. If not, then it will take most of a day because you'll have to drill out the old lock cylinder.
That's incorrect or you've misinterpreted what the dealer told you.Please note. If you do not have 2 pats keys and your car at dealer they cannot match up the cylinder..
Before you try that, go purchase a new lock cylinder from the Ford dealer, and have it keyed to your spare key...
You're right, you can't have a new PATS key programmed with a single key. You don't necessarily need to.But you cant have a new pats key programmed with just 1 key i was told. How do they get the signal from the normal key, as it would not start the car...
Warning:You might be able to get it to turn again by spraying WD40 inside the lock cylinder and tapping on the key with a hammer. Before you try that, go purchase a new lock cylinder from the Ford dealer, and have it keyed to your spare key. When the key turns, leave it in the ACC position. We have directions on here for changing the lock cylinder when the key turns, and when the key won't turn. If the key will turn one last time, then swapping the lock cylinder will take less than an hour. If not, then it will take most of a day because you'll have to drill out the old lock cylinder.
So your exact situation then?alright, so i only have one PATS key. its the only key i have, no spare at all. can i still replace it myself? i'm getting mixed answers
thanks for the quick responses guys!
You were told correctly, as it needs two previously programmed coded keys (ones that already operate your Focus's engine) and the new unprogrammed key.But you cant have a new pats key programmed with just 1 key i was told. How do they get the signal from the normal key, as it would not start the car...
