1 - 3 of 3 Posts
Hi All,
First things first, i've done a ton of research plus trial and error on programming an aftermarket flipkey fob for my '15 focus. I, cannot, for the life of me, get my car into programming mode. I've tried 4 turns, 6 turns, 8 turns, seatbelt on/off, wrapped around my neck....Anyway, I found a post on these forums that gives instructions on programming a third key, which sounds like just programming the third transponder chip to allow starting with the key, but does this program the fob as well? I'm a little confused, I thought this was a two step process. Are the transponder chip and the key fob related? I haven't had the key cut yet so I was just focused on the buttons for now. What am I missing?
Thanks
Wes
Hi All,
Thanks
Wes
That’s cos on the mk3 keys can only be programmed by Ford, there is no sequence
Sent from my iPad using Tapatalk Pro
Sorry I let this get completely buried. So what exactly can't be programmed, the transponder chip? If that's the case i will just rip the one out of my factory key, along with the cut key, and put it in my flip key fixture. But can the remote locks and engine start be programmed without Ford? I'm assuming these are two different processes. I can't find any definitive info on this.
Thanks
1 - 3 of 3 Posts
