1 - 8 of 8 Posts
hi, I have changed my engine on my ford focus 1.6 2008 module cause it had a hole on the block and water and oil mixed. it starts perfectly, but when I accelerate the revs does not exceed 2000 rpm and the car stales, a small noise comes from the chain side when the car gets hot, we changed MAF but still doing the same, please advise ?
thx for replying we have check fault code & it showed MAF was fault we changed it but now the engine light is on and no fault codes showing -
Yes we the mechanic double check, the assume its something to do with the crankshaft! When the car is cold it revs fine just when it gets hot the problem starts. The removed the part where the oil sit apparently to clean "intake"! my car is at the garage since December and they cannot seems to figure out what the problem is.
Discussion Starter #8
sorry and when the car is hot it back fires when revving & what can cause the rattling sound on the left side of the engine
1 - 8 of 8 Posts
