1 - 7 of 7 Posts
Just installed Steeda CAI and the gas pedal seem to be more stiff and harder to press. Has anyone encountered this issue? I resetted the MAF tube to the TB and then took it for another spin. It seemed stiff at first, but loosened up after that. The white face of the TB is clean when I look at it. The TB was closed, so this was the outside of the TB that I looked at. Any ideas?
Take some throttle body cleaner, have somebody hold the throttle, and clean around the little "white face". If this doesnt work then pull the cover off where youre throttle cable goes into the engine bay and see if your spring or something is out of wack...
What year is your car?
Good that you got it fixed. I figured it was a models with throttle cables and not throttle by wire like my 08.
No problem, had the same problem myself except my throttle wouldnt open at all so i had to pull the cover off the throttle body and manually open it and clean it.
1 - 7 of 7 Posts
