It won't be plug and play as the wiring isn't there. If you were handy with audio work you might be able to do something with it, but it would not be a factory clean install. The main vehicle wiring harness is different.So I got a 14 ST1 in race red. it has the base stero w/o factory sub.
A friend has a 14 titanium with factory sub that he doesn't use. Can I install it in my ST and it work?
They would be noticeably larger regardless if you had a 13 or early 14 v.s. the later 14. The difference between the two is the 13-early 14 has a 12.6" front rotor v.s. the 13.1" (335 MM /13.18") front rotor on the post 3/31/14 builds.When I looked at my brake rotors on the front are noticeably larger than the rears.
Great to see Ford upgraded the front brakes. Would the calipers be the same?They would be noticeably larger regardless if you had a 13 or early 14 v.s. the later 14. The difference between the two is the 13-early 14 has a 12.6" front rotor v.s. the 13.1" (335 MM /13.18") front rotor on the post 3/31/14 builds.
The Rear rotors are the same 10.6" diameter as the base Focus.
It's not certain, but if they were the brackets would have to be different. It went from the Escape front rotor to those from the MKC based on the part number.Great to see Ford upgraded the front brakes. Would the calipers be the same?
