1 - 2 of 2 Posts
The bracket is cracking and has weakened to the point that depressing the gas pedal to WOT will bend the bracket.
I found a few old threads on this issue that mentioned welding in reinforcement but they had broken photo links, and I haven't had any luck searching for the "revised" bracket from Jackson Racing that wasn't so prone to bending.
At this point what would be cheaper, having this one welded and reinforced or having an all-new one fabricated? Anybody have a revised bracket lying around?
I also found a couple threads mentioning that these had the potential to snap the throttle shaft due to lack of clearance between the bracket and TB here.
It's not currently hitting, but if I modify this bracket should I have this part of it removed?
1 - 2 of 2 Posts
