1 - 3 of 3 Posts
Have an issue. I can't get the intake manifold off. Does anyone know if the blower has to come off first or if there are any hidden bolts? It seems like it is stuck to the block. Previous owner used a rubber gasket that looks like rtv but I would t think that's what is holding it up. Thank you
Here's a link for the install instructions:
https://manualzz.com/doc/24325114/ford-focus-supercharger-system
Flip thru the instructions to see what step you might be at and/or maybe one of the pics may help you on what you're looking for....
Hopefully someone here might have these instructions in color....
Personally I would have a bright LED flashlight and inspection mirror, tracing the body/shell to see if there's any bolts you may have forgotten.
Doing this from the bottom looking up & from the top reaching over. Maybe get a second set of eyes to help you.
After that, you may have to "lay" a piece of wood/timber [length wise] and give it "Love-Taps" to loosen it from the RTV.....Then go from the bottom & tap it from the bottom-side...
This is what I would do...
1 - 3 of 3 Posts
