1 - 6 of 6 Posts
Anyone using the JR supercharger from Focus Central? I was wondering if I could get additional power out of it with intake and exhaust mods. Jackson is claiming at the crank, 189hp and 158 ftlbs with it on a stock engine. I understand it will be instant throttle response versus a turbo that will have some lag, but with turbos that can put 200whp, the turbo would be faster- UNLESS some additional mods can up the power that the supercharger can produce. Just wanted some opinions here.
depends on how much you want to spend and what exactly your looking for out of the car. You can get some T3's to start spooling at about 2500 RPM compared to some bigger ones that wont spool until 4K.
you can get 200whp out of the JRSC but it requires alot of work and time and tuning, and by the way you probably will have about the same money in the SC as you would in a turbo and the turbo can produce more power
FF #1 Most Wanted
Not sure where mini-muscle got his numbers but the JacksonRacing website shows a dyno with 150.2wHP and 129.5wTQ.
Not sure if the Focus was modded or not with these numbers or the PSI of the blower.
Those low torque numbers bother me. There's about a ~45% increase in HP but only about a ~17% increase in torque.
FF #1 Most Wanted
If it had 140lbs of TQ at 7000 RPM instead of 115lbs of TQ at 7000 RPM, you would get about 186wHP instead of 150wHP if you do the math.
1 - 6 of 6 Posts
