1 - 20 of 69 Posts
I had this problem for a long time now. I would say from 25k. Right now I have 45k miles.
I installed volt gauge, that is why I'm thinking this might not be normal.
The problem:
When I come to a stop, red light for example. Sometimes (often) car starts to sort of bogs down, voltage drops to ~13V and then it recovers and everything is back to normal.
It doesn't occur right after I stop. I could be stopped for 30 sec and then it happens.
Does anybody experience anything like that?
While driving everything is fine. Only when idling this happens.
Any response/ideas would be appreciated.
Thanks!
MY car does the very same thing, I always just ignored it but I would like to know as well.
is your defroster on (it kicks on the a/c compressor..)
only reason im askin it that i think every car does what your sayin when the a/c compressor kicks on..
mine does this also, i think it is normal, and i have had my alternator replaced too and nothing changed
Same thing boys... Lights dim if they are turned on (interior/dome). I was thingking alternator as well but seems like someone already tried replacing it with no luck. :(
my old car used to do the same, especially when the A/C compressor kicked on. it was a (very) dirty throttle body.
Discussion Starter #11
A/C is off, defroster is off, everything is off lol...except the engine. Very strange.
I was also ignoring it, but when I saw that voltage drops I started wondering if there is an electrical issue of some kind.
Boys, we have to get down to this. I've been doing research for awhile but i don't want to throw parts at it. A lot of having the same problem. Is it something we have to live with or what ?
ELVIS LIVES !
Maybe the the fan kicked on and caused it to bog for a second.
No... this happens regularly. It's not the fun. This happens when an electrical load is introduced or i guess any load. Braking, heater, high beams, a/c. So if you are just in Park idling and you press the brake pedal the dome light will dim with voltage dropping and going back up.
I was pretty sure it's the alternator, but as someone mentioned they have tried replacing it with no results.
check your grounds... give all three a good clean... make sure its a metal to metal connection.. or maybe do the big three upgrade. if its not the alternator.. could your battery have like one dead cell? i donno, just playing with ideas here lol
A few things to try.... reset the ECU, clean the MAF sensor and clean the IACV
Whats happening is when you come to a stop the ECU is letting the rpms drop too much before it catches the idle... I've seen it a hundred times.
You may also try complaining to the dealer, there maybe a new ECU flash out to fix it.... Ford usually releases several flashes for their vehicals trying to get everything right.
I did the big 3. ECU was reset many times before with no luck, as well as cleaning the MAF and IACV. :))
It's happens not only when coming to a stop. Just during the idle. I can be in park or Drive, but i think it's a bit worse it Drive. The thing is that the vibration has a pattern. It's not a through out vibration all the time.
It's like bbbbb-------bbbbbbbb------bbbbbbb---- XD (nice diagram)
Bbbb is the vibration and the second it vibrates the dome light flickers and goes back to normal with vibration gone and then it happens again. Seems like a cycle.The time gap between vibrations can be 2-4 seconds.
It doesn't happen while driving, that is why i was suspecting alternator before.
Discussion Starter #18
Exactly^^
It is idling normally then out of nowhere starts to hesitate for 2 sec and then back to normal.
Also the thing is this is not when coming to a stop, this is when you sit for some time at a red light.
It seems to be doing this only when car is fully warmed up. After the cold start it doesn't do it until warm.
I also cleaned TB, MAF, changed spark plugs, reset ECU, updated my ECU about 4 month ago.
The thing about going to the dealer is #1 It might not do it there. 2. they say it "feels normal".
hmm interesting... im stumped lool! ive noticed something like that with mine... but nowhere near as severe... at idle occasionally id feel the car bog for 1 second and then itll recover...
orenge svt hit it rite on the head check thoes things and your battery conections
1 - 20 of 69 Posts
