I want to seafoam my car but I also want to be extra careful so I have a question is this the hose I should pour the seafoam in?
[Picture below]
[Picture below]
How is my post wrong? I answered the guy's question didn't I? He asked if that was his PCV hose and I answered "Yes that is it." Look at the title of this thread...Post number 2 is wrong concerning where to add the seafoam, but is right on if that is the PVC hose.
Can you please answer my 2nd question above your post.NOOOO! THAT IS NOT THE PCV HOSE!! AND NO YOU SHOULD NOT PUT SEAFOAM IN THAT HOSE! that is what Svtzx555 is saying.. and this is true!! that hose pictured is the valve cover breather hose... the PCV hose is at the back of the intake manifold and no you should not even put seafoam in that hose... you use the brake booster line...
Actually that IS the PCV hose.... our Foci have 2 of them.NOOOO! THAT IS NOT THE PCV HOSE!! AND NO YOU SHOULD NOT PUT SEAFOAM IN THAT HOSE! that is what Svtzx555 is saying.. and this is true!! that hose pictured is the valve cover breather hose... the PCV hose is at the back of the intake manifold and no you should not even put seafoam in that hose... you use the brake booster line...
hmm strange american foci.. we only have one pcv hose assembly for the 1.6, 1.8 and 2.0 variants.. that hose shown in the picture for us is the valve cover breather hose. it goes from the valve cover to the intake box.. :SActually that IS the PCV hose.... our Foci have 2 of them.
I poured 1/3 into that line...I thought it might be the other line personally but when I read the first guys post i figured i was wrong so I went with him because I had to do it pronto...NOt a great idea to put Seafoam into that hose; however, the manufacturers of Seafoam actually do recommend using it in engine oil in the amount of 1/3 to 1/2 pint, albeit poured into the crankcase to mix, rather than into the engine directly.
http://www.seafoamsales.com/motorTuneUpTechGas.htm
While it never hurts to change the oil after sonething like this, it would appear that if you only put 1/2 a pint in, whatever damage it might have done is now past news, and it being in the oil is unlikely to hurt anything more.
