1 - 9 of 9 Posts
My 2017 Focus RS made 245.8 Whp at the front wheel "stock"
I see differtent Hp output in different country and most of the RS in an Australia are making 280 + stock so what's the go???
We tune with HP or VCM and flash the ECU that way
Bolt on: with all the upgrade down below I made 292.7 Whp and 440Nm or 324.53 Foot-pounds
BOV cp-e upgraded the spring to 12psi
Wastegate is closed until 17 psi
we have 26 of boost
Extreme twin clutch
cp-e: air intake, hot and charge pipe.
ETS: intercooler
Mishimoto: oil cooler
dump pipe
No way to tell for sure without bringing another RS to the same Dyno. Dynos vary so much you can compare numbers.
Sent from my SM-N960U using Tapatalk
Also just to clear up confusion you say front wheel stock. You did use a AWD Dyno right?
w/ my magic bag
That seems low as last Saturday at Ocean Shores focus wars I've seen stock St's at 215-220 & moddit ones around 250-275 ....btw I'm knocking on the door of 200.
w/ my magic bag
A stock RS should be at 310......
1 - 9 of 9 Posts
