Status
Not open for further replies.
1 - 4 of 4 Posts
underdrive pulleys-who makes them, and are they worth possibly destroying your perfectly good duratec? how rough is the install on them?[wrenchin]
im curious why you think UDP will destroy the engine. I run an UDP on my zetec no problem. Also, people remove the balance shaft on the Dtecs all the time, and arguable that would have more of an effect than an UDP.
as for intsall, it works best with an impact gun, so you can get the crank bolt off without have to try to keep the engine from rotating.
im not sure about the UDP, but def get a balance shaft delete, its really an easy mod and gets un-needed weight and rotational mass out of your engine, and has NO side effects
1 - 4 of 4 Posts
Status
