You can feel the engine running normal and after a couple of seconds slight revving increases for 2 or three seconds, then comes back to normal.
At a red light you can also feel it, specially when you press the break pedal you have to press it a little harder to avoid the car from going.
At idle speed goes normal, then increases speed very little for a few seconds then back to normal. All this is constant, happens al the time I have the engine on.
I changed the idle control valve but problem remains.
Thanks a lot
Thanks a lot
