1 - 7 of 7 Posts
Im not sure if its my IDLE AIR CONTROL VALVE or what but I live in iowa and for the last month when I start my car up it idles hi but then wants to die but if I tap the gas it idles back to normal I dont know what i could be would love some help.
Shot me 3 deer!!!
sounds like a vacuum leak to me.
It only does it when I start it and once i rev the motor up it will go back to normal and run fine only does it on first start up no vacum leak I check ed all of the lines
is it cold? in the cold the motor will idle high to keep warm it should die down a little bit after.
zetec 2 duratec swap
i think all cars will rev high to warm up. but dying would be from something else. try cleaning your maf sensor and see if that changes anything
well like my car if i brake in nuetral really fast once it stops the rpm drops a little for a second but goes back to were its supposed to and just sits fine.
It all stems from when I put the svt factory intake on it idles high then will drop down and then idle way below and feels like it wants to die so I rev it up and it goes back to normal it does it when its cold and once in a while when i drive it
And I do have a sct xcal program that I installed o2 delete and egr delete
1 - 7 of 7 Posts
