1 - 15 of 15 Posts
I have been searching for hours for the spring ratings on the Intraxs, but I can't find the exact numbers. Does anyone know the exact number for these?
Very tight springs. The drop is excellent, at least to me it was. Just about a finger's width of daylight left between the top of the tire and the wheel well. Beware if you live in a place with bad roads. These are very hard on stock struts/shocks.
what size tires are you running?
Im running the intrax svt springs, and the kyb agx's on medium front/rear. They are an awesome handing combo! Running show wheels 215/35R18 tires on a 7.5" wheel, track wheels 205/45R17 on a 7" wheel and 195/50R16 for winter stuff
i'm thinking about the intrax svt springs for my zts. I'm hoping the drop is no more than 2 inches for me if i use the poly spring isolators.
I'm debating between 215/45/17 or 215/40/17. I'd rather have a little larger gap to the fender with the 215/40/17, but i'm afraid to dent a wheel
right now i have stock wheels with 205/50/16. If i go to 215/40/17 the overall diameter will be slightly smaller and 215/45/17 will be larger but a bigger difference than the 215/40/17's. I'd rather go with the smaller diameter but am just worried that the sidewall may be too short. guess i'll just have to watch out for potholes
Wheel King, Bow Down
I've heard nothing but good things about Intrax. I should be ordering my set this summer! Side question, should I purchase a set of camber plates for the front (running 17x7 "Tuner" 16 Spokes) or will the camber kit for the rear be ample[?]
how is the drop? the stiffness, any sag... since i saw more posts against them then good ones on carreview.com... or something like that...
i seen that intrax offers a linear and progressive rate on summit racing....does anyone else know about their linear springs...i thought it was only progressive.
1 - 15 of 15 Posts
