1 - 20 of 22 Posts
Ok, the tutorial for painting the interrior is good for telling me how to get the stuff out, but it doesnt really explain the process. should i sand down all of the parts before applying paint? also should they be primered? for all of you who have done the painting how many coats of primer/paint/clearcoat did you do? thanks!
i painted my interior recently and came out really good. i just took them out, washed them good with soap and water, then i did 3 coats of primer and make sure theres no runs, then 3 coats of paint, and then 5 really thin coats of clear coat. they came out really good, it is super clean and had like a mirror finish.
yeah. that sounds about the same as how i did it. take them out, rinse with water. sometimes a REAL light alcohol rinse, to get any kind of oil off the surface. then 2 coats primer, 3 coats paint. then 3 coats clearcoat. i have yet to have a single problem.
i only have a good picture of the guage surround, but here's the finished product. i masked off the "inset" area, so it creates a nice contrast in color.
Discussion Starter · #5 ·
that looks really sharp. how long does it take to dry? my car is a daily driver so will i be dricin around without those parts for a couple days?
i used a weekend to do mine. i know you don't need NEARLY as much time as that, but i painted everything on saturday afternoon, let it dry overnight, and then put everything back in on sunday.
that looks really good scironzts. good job [headbang]
thanks. :) i'm gonna eventually do some more painting, but i'm keeping it subtle for now.
cant wait to see your final project
the tutorial your talking about is probably mine. well i lightly sanded with 2000 grit sandpaper, painted 3-4 light coats of krylon paint waiting a few minutes for the paint to set, then i allowed the paint to dry to the touch which is about 10-20 minutes depending on humidity (the dryer the better, i work at a body shop so i had the paint booth to dry mine in) then i applied the clear polyurethane paint a total of about 4 layers to give it a thick protective coating from scratches and thin spots in it when dry. any other questions leave a message here and i'll answer asap. good luck i hope that helped.
for me the paint was a total of 10 dollars for 3 cans or so or so and the polyurethane was like 5 dollars from where i got it. you can pind the paint at any hardware store or paint section at any department/grocery store
for me the piant was about 9$ and the clear coat was an extra 3$ i got it at an auto parts sotre so i could match the exterior color
I need someone's opinion on my interior color. My dash is a light grey, I wanted to do a metallic silver on the interior, but will it look bad? Gimmie some opinins here.. please..
~Tiffany
did you sand yours down or did you jsut prime right over the original?? I think i might go to a junk yard and get some scrap pieces to try it out before I screw mine up.. will it cost me anything to do that?? from the junk yard i mean...
~Tiffany
~Tiffany
i had the light grey in my ZX3. i had painted all the dash pieces (vents, radio/guage bezel) red, but that got old real quick. so i repainted everything "black metal flake". it was black with little specs in it to give it some shimmer when the sun shone on it. looked dope as hell. i definitely recommend that on a light grey interior.
~Tiffany
i just cleaned mine thoroughly with some alcohol to get all the fingerprints/dirt/oil off of it. then primed. you're good to go with that. don'tw aste your money on extra parts.
Thanks, I appreciate the input, these are all mods I want to do in the near future.
scironzts: did you buy the color as is or did you mix it yourself??
~Tiffany
are you going to be posting any pics of your car soon 03chromechica? would like to see what you got so far
~Tiffany
bought it as is. i think it's a duplicolor product.
1 - 20 of 22 Posts
