As usual, the only times any problems occur is when the temperature drops below freezing.
Problem started last night. Heat started working normally, but then noticed after a while that it was blowing cold air. The heat seems to come on intermittently. There are not any problems with the blower.
Already did some searching. Here's what I plan this evening:
1. Check coolant level.
2. Replace thermostat.
3. Flush coolant.
I'm hoping it's just the coolant level as I haven't given it attention in a while.
Any other thoughts would be appreciated.
3. Flush coolant.
