1 - 8 of 8 Posts
· Registered
ok so i have a set of LED interor strips that have to be wired into the car where can i wire these up to i was told a long time ago the i could go into the fuse box but is there another way?? and if so how about would i go about wireing these in??
· Focusless
not to thread jack, but i recently went to autozone and got one of the add-a-circuit things. but i dont know which spot to plug it into..? can someone help me with that?
· Registered
I believe the Add-A-Circuit is used for a positive connections only. I've never used one but on the pictures I've seen there's one wire coming from the unit. Your LED strips can't have the positive and negative together in one wire, they need a positive and ground just like a standard light bulb. You might have 2 small wires inside a sheath, see what you can find out.
· Registered
I think it should. positive to add-a-circuit and neg (usually blk) to ground..one of the screws holding the box should do it. please correct me here if I'm wrong....
· Banned
^^ Your right you can use on of the screws in the metal. I used it for a while the positive will go into the add a circuit might put a switch so you have complete control however LED's wont kill the car.
I had a ICELED UFO kit with a TON of other LEDS. Could leave them on for days with no worries.
1 - 8 of 8 Posts
