1 - 4 of 4 Posts
Will front end body panels from a 2005-2007 fit onto a 2000-2004 car? I was doing some checking and know that the structure of the car is the same just not sure if i can put the front end on my 2001. Thanks all Dave
Hatch Nation #136
You can put anything onto anything else with enough work.
That being said, you should be able to swap out the front clips with little issue. You'll need the hood, lights, and bumpers. The fenders are the same, IIRC.
You may have to fiddle with some wiring and drill holes to make everything gap correctly.
Posted via FF Mobile
thank you very much for the links. i was obviously not using the correct search terms because that never came up. what is the difference between a MK1 and a MK1.25? have never seen those before that write up or i just never paid any attention when i did. thanks dave
1 - 4 of 4 Posts
