1 - 3 of 3 Posts
ok so i read the faq section and it said intakes will fit from a zetec to a SE which is wat i have. but will the intake from a dohc engine fit my sohc engine?im not sure if zetec is only on the dohc or if its both.but i can aquire a intake off a friends a focus which is a dohc and was just wondering if i should get it , if it fits. ps- i have a 2003 SE
It will fit, all you need is a reducer hose/fitting. The zetec intake/throttle body is larger than the SPI throttle body. If you want you can pick up a larger t/b from focus-central.com, blackdiamondracing.com
1 - 3 of 3 Posts
