Hey Tom, quick question for you.
I'm getting a FR IM and a 75, yes, 75 mm tb that is matched for the IM. this is wider than the intake tubing. so will the stock (if i stayed w/ a stock) intake diameter hurt velocity? IIRC, the intake tube is about 70 mm? not sure. but if the tubing is narrower than the tb/IM opening, will this help torque by speeding up air intake velocity? or will a wider intake tubing help? not sure which way to go w/ this. also, this will be for my rally build. i'm using a zetec, not the 2.3 like i originally wanted. so i will be going for power up top, custom ported FR head, stage 3 or 4 crower cams, (not sure yet, but probably stage 3) 12.5:1 CR on 116 octane, etc.
thanks for your imput as always tom!
mlb
mlb
