1 - 3 of 3 Posts
· Registered
What should i do if the button you push to reset the trip odometer broke off and isnt in the hole anymore?? dont remember how it broke off but it isnt there anymore. would i have to get a new instrument cluster or what?? thanks
· Freeskiing Fanatic!
yea, probably. or just fashion something that will work as one.
· Registered
On my 07 cluster and the 06 cluster I bought, that button is removable. I don't know if the earlier clusters are the same, but I'd imagine it's still removable. You can try this and see if it helps.
If you take the cluster out and take out the bolts holding the gauge face itself, you should be able to move it enough to look behind and see the back of the button, mine has 2 clips that hold it into the hole. If you press both of those in and hold it upside down what is left of the button should come out. To replace it just slide a new button down the hole and it should snap in.
1 - 3 of 3 Posts
