I have read posts with similar problems on this Forum, but my problem is slightly different. My gauges on the instrument cluster are not working. Temp, Speed, tach, and fuel gauge do not move when the car is started or turned to the run position. The lights on the instrument cluster work. But the LED reading for the odometer does not display showing the mileage. When you turn the key on the normal lights that display illuminate. The turn signals, flashers, heater fan, radio, headlights, tail lights, brake lights, cruise control all work correctly. But do not get the light on the Instrument cluster showing the cruise control is on. Also, the engine light was on for an EGR problem, and now the engine light is not on. If you drive the car it runs fine, the only problem I can find is that the gauges do not work. I checked all the fuses under the dash and they all seem normal. Any suggestions???
2003 Focus ZTS... 2.0 135000 miles...
