Well this is a easy mod to do. As long as you have power mirrors.
Requirements:
05+ Heated mirrors
Tools:
t-20 torx
10mm socket/extention
panel removal tool
flat blade screw driver
How to:
Remove the corner sail panel pieces( no need to unplug the controls on drivers)
Unscrew t-20 screw just infront of the door panel
Remove *********** miror connector from door, and unplug. (to make sure it will work check the plugs on the car and the new mirrors, mine both had 5 pins)
Peel back the foam from the door.
Remove the gromet from the door and the wire. it's below the edge of the door panel
Unbolt and remove mirror
Reinstall in reverse order
The real hard part is wiring the mirror heater, just plug in the mirror. NO extra wiring needed.[
Tim
Disclaimer: This should work on most Focus that has power mirrors. It worked on my 07 SE sedan. whether or not it will work on others is unknown.
Requirements:
05+ Heated mirrors
Tools:
t-20 torx
panel removal tool
How to:
Tim
