1 - 9 of 9 Posts
has anyone ever tried this?
right now i have halo projector headlights like these
http://www.ilovebodykits.com/produc...lo_Projector_Headlights_Chrome_w_HID_Kit.html
unfourtunally they are chrome i wanna pop them open and paint them black
http://www.ilovebodykits.com/produc...lo_Projector_Headlights_Black_w_HID_Kit_.html
like so
and insted of having the led halo rings which uses 16, 194 size bulbs
i wanna put in these
http://www.kryptonbulbs.com/Halo-Rings/green-halo-rings-angel-eyes
is their any leagle issue with green lights in NY?
also how could i mount them up and what size do i need from the outside it looks as thos at the halos widest point their about 75mm and the inside diamater is about 65mm there is also an option for clear protective colvers
when you look at the picture of the green halos they look like they have mounting holes but the white halos with the covers just look like its a thicker ring
covers on
http://www.kryptonbulbs.com/image/cache/data/misc related bulbs/white halo with cover on-250x250.jpg
http://www.kryptonbulbs.com/image/cache/data/misc related bulbs/halos cover 1-250x250.jpg
http://www.kryptonbulbs.com/image/cache/data/misc related bulbs/green-250x250.jpg
covers off
http://www.kryptonbulbs.com/image/cache/data/misc related bulbs/IMG_1494-250x250.jpg
i would say get them covers on with out mounting holes cause then i could probly just use some kind of glue hot glue probly
Dat boxer rumble
Most states are very strict about what color lights are on your car.
Blue lights are supposed to designate emergency vehicles, such as police, ambulances, fire trucks, etc.
Green lights are used on signals as go, and though its far-fetched, some would say that they can confuse people. IE, green light = go.
So, id say to be safe, no go on the green lights, go yellow or white.
well when the green lights are comin from behind you it means get outta my way :)
i didnt do any of this yet but a couple months ago i put on some green laminit on my foglights still free from the cops for now
I would just remove it. Trust me, you dont want that kind of attention. You'll get pulled over for it eventually then ticketed for random other things. Its happened to me before.
In some states green can be used by fire chiefs and volunteer EMT's so this can still be considered an emergency vehicle color. You'll most likely just get a ticket for illegal/improper lighting.
I used to see green lights on taxi cabs. It meant the cab was empty and available. If the cab was in use, they would use red. I think they were on the roof lights.
Dat boxer rumble
Pizza-hut and Dominoes both have blue on their delivery car box lighty things as well, and here in CA, they were required to remove the bulbs from them. Im not 100% on the laws, as im sure they change from state to state, but either way, the best option is to go the safe route. Dont give police another reason to pull you over.
Also, after re-reading the post.. $350 for shitty ebay lights with hids in projector housings is pretty friggin hysterical. You can pick up a set of Machs for that price. THe ebay lights will burn the projector housings, and even new, the output will be worse than a stock reflector housing. THe Machs however, are about as good an output as you can get for our cars.
Discussion Starter #9
i didnt buy the lights they came on the car i was just using that for the picture
1 - 9 of 9 Posts
