1 - 3 of 3 Posts
I got some directions off of myfordfocus.com and to depressurize the fuel system it says to crank the engine for 5 seconds. How do I do that? Just turn the key?
pull the fuel pump fuse (just look in owners manual to find it) then crank it just like you want it start it. I let it run until it stalled because it did start sp that the gas out of the line when I did took it apart, made somewhat less of a mess I suppose.
you could also trip the fuel cutoff switch which is located in the passenger kick panel. just remove the little cover, flip the tab, and crank the key til the thing dies.
Mike
1 - 3 of 3 Posts
