The inside door handle on my '04 ZX3 has been kind of wonky on me. After driving up to whatever speed and having the doors auto-lock, when I park and pull the handle to unlock/open the door sometimes it just...won't open. If I try it enough times sometimes it will, sometimes it won't. The following has so far always worked though:
-Hit the unlock button on the key fob before touching the door handle.
-When not working, roll the window down. Most of the time this makes the inside handle work. The other times I can just reach out and open the door from the outside.
Additionally, I heard something rattling around in the door when I'd open or close it. Today I took off the door panel and started poking around. I couldn't see anything out of place immediately with the cable, so I just started reaching around in the bottom of the door to see what was loose. I found these:
Having never taken this stuff apart and not seeing more in there without ripping apart the foam sound deadening, can anyone point me in the right direction of where this widgets go?
