The motorcycle ones are a cheaper but much more difficult to get setup right. finding the right set that will match up inline with your intake portswhile keeping the linkage working, rigging up a throttle cable, having an in take manifold made to mate the two together. but the biggest hurdle is in the engine management like sailor said. Hope you know how to tune or know a good one.First off, you need a set that can be adjusted to work together, such as a set off a Motorcycle. (Don't know what "4 age throttle bodies" are)
And before trying this, besides TB setup, air cleaner setup & throttle cable hookup, you need to consider what stand alone system for tuning the engine you're going to use.
Megasquirt?
and that's just the ITB's. drop anther 1-2k to get the car to run. [rofl][rofl]Here's a thread that includes custom ITB's on a zetec, just to give you an idea what might be involved in an individual project: http://www.focusfanatics.com/forum/showthread.php?t=302371
Jenvy has a nice setup, only about $1,700 :http://www.jenvey.co.uk/home/throttle-body-kits/jenvey-dynamics/ford-2l-duratec-tbp45-throttle-body-kit-ckfd07
ITB's on a street car are pointless as you have to rev stupid high to get/gain and type of performance. If you are going to a strickly "LOOK at me!" then they''ll do it.ONLY $1,700 for the ITB's alone didn't come off right I guess, it's a lot of money for what you get & you're not near done at that point as twiggss emphasized.
If you're up for dropping a LOT of money, forced induction is a better route.
ITB's are most popular for racing series where N/A is required, or other places where tuning will be done anyways (engine swap like the one I listed earlier).
4AGE is the code for a Toyota engine, which could be had with ITB's from the factory on some overseas variants. Much like motorcycle throttle bodies, used 4AGE throttle bodies are pretty popular with DIY'ers.(Don't know what "4 age throttle bodies" are)
Isn't that kind of like saying a tubo won't work well on a street engine because it won't spool until 4000rpm and will need substantial head work to properly support the massive surge of high rpm power? Sure that could be true, if you pick the wrong one for the application. But 6 inch and a 12 inch runner lengths will not behave the same, nor will 38mm and 48mm body diameters behave the same. While I agree that it would be considerably easier to just install a Cosworth style manifold, I would be surprised if a well implemented ITB setup could not be put together for for nice streetable gains in addition to the cool-factor.you won't have a power band till 5000 or so but you'll be knocking on 10k revs.
awesome reply! glad to know there are some people on here that can spit out more than 1-2 words on a subject. [like]4AGE is the code for a Toyota engine, which could be had with ITB's from the factory on some overseas variants. Much like motorcycle throttle bodies, used 4AGE throttle bodies are pretty popular with DIY'ers.
If I was going for fancy ITB's, I'd probably go with the smaller Raceline DTH set...But I'm too cheap for that, so I've been putting together a GSXR based ITB setup. I was lucky enough to score a Duratec DCOE manifold on the cheap, even if it's not as nicely finished as the Jenvey piece, and have also picked up a set of 42mm GSXR 750/1000 throttle bodies of the years that are able to be individually respaced to match the DCOE pattern. I'm not sure if they'd be 'too small' for even a stock Duratec, but there are even cheaper and more readily available 38mm GSXR 600 throttle bodies of certain years that were also able to be individually respaced. Since mines going in a Vintage-ish looking car I specifically went for the ones that had the manual high-idle contol that can be actuated via a 'choke' cable, but they are available with an electronically actuated high-idle as well that would probably be better suited to more modern installations.
Alternatively, it is absolutely feasible to fabricate a manifold to connect the throttle bodies to the engine. The advantage to this being that pretty much any throttle body set could be used, as the manifold to throttle body interface could also be made to match the original throttle body spacing.
It's not really applicable to me, but as far as the ECU is concerned on Focus installations, is there any chance that the stock unit could be tuned to handle ITB's that are enclosed in a sealed airbox utilizing a MAF?
Another challenge in a Focus would probably include finding enough space to fit it all.
you can't post that without some youtube clips.now if money was no object...a cosworth 2.3 crate would be pretty sweet as far as n/a goes:
http://www.sevenspeed.co.uk/collections/engine-performance-parts
http://www.cosworth.com/media/335568/duratec_components_catalogue_2009_v1.0.pdf
I think the caterham csr's use them...YouTube for more but here is one: Caterham CSR Super…: http://youtu.be/fK-IOMbsdsgyou can't post that without some youtube clips.
Yes that's pretty much what the Cosworth intake manifold is emulating, but no they still don't quite work the same as a result of the throttle location relative to the plenum volume.It seems that itbs in a sealed box fed by a maf would be awfully similar to a cosworth intake?
