Well the Focus would not start this morning. Had to jump it with the wife's Murano. Gave me OBD II codes p2610 and p068a. The clock also never changed from 6:58 am....[mecry]Oh wow...sounds like the computer decided to take an early retirement...
I've never come across that myself...
P068A - Indicates the non volatile random access memory (NVRAM) write did not complete successfully after the ignition key was turned off, prior to PCM shutdown. This DTC sets when the PCM power relay is de-energized too early.Well the Focus would not start this morning. Had to jump it with the wife's Murano. Gave me OBD II codes p2610 and p068a. The clock also never changed from 6:58 am....[mecry]
Any one had this happen?
Hmm... sounds similar to my issue - not having quite as many of these problems (yet)...intermittent harsh engagement/shift...
You had to jump start it,Well the Focus would not start this morning. Had to jump it with the wife's Murano. Gave me OBD II codes p2610 and p068a. The clock also never changed from 6:58 am....[mecry]
From the TSB:So, this is a new TSB that just came out. That's a lot of issues all packed into one TSB.
Appeared so. All the electronics worked inside the car. Heard a click when I tried to start it. Kept clicking rapidly until I hooked up the jumper cables the the Murano then stopped . Had to let it charge for a few minutes until it did start.You had to jump start it,
Was the battery flat ?
Woo-hoo! I have the 70F - and its consequently killing the operation of my HVAC. Thanks for posting this! I'll bring it with me when the car goes in next week.P068A - Indicates the non volatile random access memory (NVRAM) write did not complete successfully after the ignition key was turned off, prior to PCM shutdown. This DTC sets when the PCM power relay is de-energized too early.
P2610 - Indicates an error in the internal PCM engine off timer processor. The test fails when the difference between the engine off time and the central processing unit (CPU) time exceeds a calibrated limit for a calibrated amount of time.
For these DTCs, the technical details probably aren't important because there is a TSB that covers these issues:
TSB 11-10-2
Publication Date: October 2, 2011
Some 2012 Focus vehicles built on or before 8/12/2011 may exhibit the following engine drivability and/or automatic transmission concerns; RPM flare on deceleration coming to a stop, rough idle on deceleration coming to a stop, intermittent engine idle fluctuations at a stop, intermittent vehicle speed control inoperative, intermittent harsh engagement/shift, engine no-start with engine coolant temperature (ECT) open circuit faults and intermittent no-crank/no-start condition after performing normal Powertrain Control/Emissions Diagnosis (PC/ED) pinpoint test (PPT) diagnostic procedures. The vehicle may also exhibit diagnostic trouble codes (DTC) U0422, P00D2, P068A, P0850, P2610, P2832, P286F or P2877. The vehicle may also exhibit intermittent false initialization to 21 °C (70 °F) on the instrument cluster's ambient temperature display upon engine start up.
The fix is a simple reprogramming of the PCM and TCM.
Maybe the cause of the problem was a flat battery.Appeared so. All the electronics worked inside the car. Heard a click when I tried to start it. Kept clicking rapidly until I hooked up the jumper cables the the Murano then stopped . Had to let it charge for a few minutes until it did start.
Not a fun morning...
I agree that the trouble codes could be from a dead battery or related to the dead battery, but why did my battery die and why is the clock stuck at 6:58 am? I tried to reset it several time with no luck.Maybe the cause of the problem was a flat battery.
The fact that you could start it with a jump sort of proves this.
Modern Fuel computers require that your battery voltage does not drop below about 10.5 Volts while cranking (starting).
Low battery can cause CPU's to display undocumented behaviour.
Keep an eye on your battery voltage.
U can check it in test mode.
Yes, I had this same problem, unfortunatley for me though it was not a known concern. Just went out to start the car one morning and it clicked and rattled and that was it, jump start got it going. Then it sat at the dealer for 4 days waiting for FORD engineering to figure out the fix. I was the test dummy, and you guys are welcome! Turns out a PCM and TCM reprogram did the job.I agree that the trouble codes could be from a dead battery or related to the dead battery, but why did my battery die and why is the clock stuck at 6:58 am? I tried to reset it several time with no luck.
The car is 6 months old with 7800 miles. Their was nothing left on inside the car, i.e. Headlights, dome lights truck light. Car was driven the day prior. Very confusing to me. Hope it is just a TSB issue.
I wish I could check to see if I have this issue, but... it's 70 degrees outside right now.Woo-hoo! I have the 70F - and its consequently killing the operation of my HVAC. Thanks for posting this! I'll bring it with me when the car goes in next week.
