Not sure if this is the right spot, so if not, MODs can feel free to move it where ever it may belong.
I was playing around under the dash of my 09. Did something to it that I later learned blew fuse #27 - the ignition fuse. Nearly nothing worked on the car and at that point, I had to get it towed to a Ford Dealer. I checked most fuses, but obviously the one I didn't check turned out to be the problem. Before I had it brought in, I noticed that my fogs and halos worked, which I had wired to the battery myself. When I got the car back and went for my usual night drive with my dog, I noticed my fogs and halos no longer worked. Thinking what the hell, I lift open the hood and see the wire is sliced in half about 4 inches from the battery. It wasn't as if this wire was spliced into a longer wire at this location and possibly was tugged loose. It has been straight up, sliced in two. Not only was it sliced in two, the hot side was left wide open, not taped up. So the few times I hit the switch and nothing worked, it probably sent current through the wire, luckily not causing a fire under the hood. The wire was also tucked, as if to "hide" it.
Is there any reason for this whatsoever? Maybe it's just me, but I feel the negligence here is beyond obvious. Never was it mentioned to me "hey, we had to cut up some wires you put in." Maybe someone here with much more knowledge than me would know why the dealers mechanics would randomly (to me, at least) slice a wire in half and leave it open, and not tell me.
I don't have pictures because I'm beyond pissed at the moment, but I will take pictures tomorrow for those who have a little bit of trouble following.
Any insight, help, suggestions would be greatly appreciated.
