Like thisUmmm, then how else do the needles stay in place at idle?
It must have changed in 05 then my 07 doesn't have stops and the 05 cluster i bought off Ebay does not have them.i have an 04 with a 2.3 and mine has them but i have the roush gauges
When you get to the RPM test you will know because the numbers will be constanly changing.You hold the trip reset button in when you start the car until it goes into test mode then you let go.Then you push it one time to get to a different test mode you repeat that to you find the RPM'S.I dont know what to do when the little thing says test. i dont know how to scan through or anything
Test mode will help you do the RPM needle and after you get that set turn the car off .Then follow the procedure in the other thread on setting the speedo.Ok i got it started. everything should be working but the spedometer. In test mode. what is the spedometer called?
