im going to put some more lighter wells in my car, only have one 12v plug sucks, but i want it to light up blue and stuff. not having any luck finding these, anyone done anything similar?
Wow, still haven't arrived?i ordered some wells that light up. the only place i could find BLUE illuminated wells was in the freaking UK, so i bought 3 to make it worth the shipping, $23 dollars later and theyre on there way. ill post pics once i get them put in
Friend, can you please explain more clearly? What hole is too large????? Are you saying: 1) the lit socket hole is too large for a standard cigarette accessory plug or 2) the socket hole you need to drill in your console is larger than normal due to the colored plastic ring or 3) the existing SVT socket hole is too big to fit this accessory socket or 4) Is the lighter that comes with this lit assembly has a non-standard diameter so no aftermarket plug will fit it??????????????????????I got one since then also, the hole is too large for any 12v accessory plug. It's strictly a lighter.
I had just ordered two when I saw your post...was hoping to poke a quick reply from you in time to cancel. So much for that. I thought perhaps you were talking bout the mounting hole which would be oversize due to the light ring.^^^ No need to get all worked up lol! The lighter is a very large diameter, the biggest I've ever seen, so any charger you put in is loose as hell. I could've tried to mod it to make a hybrid socket from the stock one, but I just put the stock black ones in.
