I'm from Brazil and I have a Ford Focus equivalent to the ZX3 US version. My car doesn't seen to be normal compared to other Focus and running some tests with a PCM Scanner I noticed that the ignition timing is too low. Under WOT condition it's starting at 10 degrees (1.000rpm) and finishing at only 15 degrees (7.000rpm). What would be the normal ignition timing?
