1 - 7 of 7 Posts
2000 ZX3,
The ignition switch/ lock cylinder turns freely without any issues. However today while trying to start the car it would not start ! While turning the key it would make a clicking sound underneath the dash near the fuse panel on the inside of the car. The odometer readings were going crazy flashing numbers 888.8
888.888 ETC.
The interior lights went very dim, like no power, acted as if the battery was dead.
About 1-hour later put the key in and it started right up without any issues.
Checked it again later and she fires right up.
Somebody please help. I really need to get this taken care of A.S.A.P. and not be stranded somewhere.
What could be the issue ?
Thanks for any help.
Ray
"Could a loose connection/battery cause the odometer to go crazy like it did ?"
Yes, when the voltage gets low electronics can do all sort of weird things. It probably was going through a self-test when the voltage can back up after the relay for the starter clicked-out.
Check the little ground wire right near the battery too. (It's black with an orange stripe, and it fastens to the car body near the battery) I had that one loose one time, similar results to your symptom.
1 - 7 of 7 Posts
