1 - 6 of 6 Posts
Hello, my 2014 Focus "automatic" is having an issue with idle. In park, or when stopping, with brake applied, idle drops to around 750 rpm for about a second, then recovers to around 800 rpm. This happens after engine has reached operating temperature. Is this normal? Believe it or not, this is the first car I have owned that either does not have a digital tachometer or a tachometer at all. Check out the youtube video link below, I have enabled the digital tach readout so you can make an assessment.
Idle Speed Test
This test was done with the vehicle in Park.
The video is private, and the car has a tachometer to the left of the speedometer and ipc.
The idle behavior sounds normal since the target idle is 750 rpm when the car is warmed up.
1 - 6 of 6 Posts
