1 - 7 of 7 Posts
I have a 2003 zx3 2.3 the car starts right up idles fine for a min then bogs way down then jumps back up. It does this every few min. We have cleaned the IAC valve and the throttle body. When we unplug a spark plug it stops it just idles rough but no bogging. Please help
Sounds like your a/c is cycling on and off. And if you have your vent selector on the windshield but the a/c off, it'll still cycle your a/c. It'll put enough load on the motor to make it bog before the iac can compensate.
Your alternator can also put a huge load on the motor...
As Levi said, please confirm if this is happening only when the AC is on. If yes, it sounds like your IACV is not working or AC clutch & compressor might be adding an unusual amount of drag on the serp belt/engine.
@focusknot, the OP has a 2.3 so the famous and common cracked coil pack does not apply to that engine.
PCV hose under the intake loop.............common on these. Vacuum leak.
1 - 7 of 7 Posts
