1 - 15 of 15 Posts
· Registered
hows it goin SPIer's, this problem started a few months after i bought my car in 2006, my car a 2001 with 78K spi automatic, it idels low then it will bounce back up again to normal then kinda high.. causing vibrations and you can hear what its doing. it does it both with and without the A/c on(worse with it on) and then some times the car idels perfectly.. its like the car has its bad days?? anyone have any idea of what could be causing this and a way to fix it?? [scratch]
· Adam
Back side of the intake mani.
· Aurelius Pardus
is it normal for the SPI to have like a loud fan on sometimes, like when I turn on my ac for example??
· Registered
^ not sure, thats how my dad told me to find it, but he said to use starter fluid... mine was on the back side of the valve cover, the rubber elbow rotted out... $30 and about 2 mins to replace
· Registered
Discussion Starter · #14 ·
i couldnt phsically see any cracks or holes in any of the tubing but which ones should i be lookin at? there seeems to be three main hoses that come out of the intake manifold then branch off to other vacume lines and hoses?? what sould i do pull the hoses off?[scratch]
· Registered
just fyi have an easy way to tell if the idle air control is workin fine. Check your tach (if it's an auto like mine had to do the dash tach trick)
Start your car with all loads off (ac, lights, fan, ect.) and see roughly at what RPM your car idles.
Give it a min or so and then put all loads on the car.
If the IACV is working properly your car should compensate for the loads and increase the RPM.
I've been having rough idle for a while and trying to fix it myself. So far have changed plugs/wires, cleaned the IACV now and next up is finally getting to my fuel filter (after 80k miles [doorpeek] )
1 - 15 of 15 Posts
