Hi everyone,
This weekend I am working in my car in my friend's house. Today we have changed the fuel filter, the PCV valve, the cabin air filter, PCV air filter, air filter and checked the pressure of the A/C system. I need quick answers, because we are going to be here only till Sunday, thank you guys!
TRANSMISSION PROBLEMS
I am servicing my transmission this time. We tried to take off the cooler lines and it was impossible. We removed the clamps, moving them forward, but the rubber hose doesn't come off the metal part. We tried this for 2 hours, using every sort of thing: putty kniffes, flat screwdrivers, WD40...
It seems that the car is pretty corroded under the hood, ok it is San Diego, and I would say the rubber is now welded with the metal. We thought about cutting the lines, but we don't think we will be able to reuse them. How much would be to get new ones and what are the part names?
A/C PROBLEMS
My A/C is not working. After two hours of sweaty journey to his house, we wanted to start fixing it. I thought it was going to be a refilling issue, but no! I have an Interdinamics kit that comes with the pressure gauge. We hooked it to the low pressure port in the compressor, and did not read anything with A/C working at maximum.
So then we find out that the compressor does not start working, then we found out that the fan either. As far as I know if the fan doesn't start, neither the compressor. So we thought it could be an electrical problem. We have checked every fuse and one relay out of two. We used a 12V external battery and a multimeter for this. The point is that the other relay was stuck in there (like everything in the car) and when using pliers to remove it, the plastic box came off but the relay stayed in place.
Now, we don't know what to do to get it outside. What else can we check? some with more experience in A/C systems?
WASHER
I need to know what's the washer size of the drain plug for changing it with the oil.
CATALYTIC CONVERTER
I discovered a hole in my cat. I don't think that's supposed to be there. What can be the implications in my car. could be this provoking my P0171 engine code? any solution (maybe welding it or putting some sort of cold welding or glue)?
BATTERY ISSUES
I found out that my battery has 12.37 volts. I was told in Kragen that my battery was almost dying and my alternator was ok. The point is that I think the tension is good enough for some more time. The terminal are corroded, so I think their tester didn't read good values. I bought them a new one, but now I am wondering if the would refund me the money, what do you think?
What happens when I unplug the battery for long time. Does it reset the ECU? is there any procedure to adjust it again?
This is all, by the way the cabin air filter was never put in place. I found the Ford plastic piece inside, [
THANKS!
A/C PROBLEMS
WASHER
CATALYTIC CONVERTER
BATTERY ISSUES
THANKS!
