1 - 7 of 7 Posts
Ok...here it is. I just got an RF 401s amp and 2 12"he punch subs. I have ran all the wiring and power and ground. Since i am using the stock blaupunk Hu i used the high level inputs on the amp. Here is the problem...my left subs is working but my right sub is not. I have checked the wires and i dont see anything that could be the problem....any suggestions?
Mr. Wizard
How do you have the subs wired? Series or parallel? Is the amp bridged or unbridged?
Discussion Starter · #4 ·
Never mind...got them work...when hooking up the subs my friend forgot to strip the wires on the right sub.
Discussion Starter · #6 ·
Sounds great, still tinkering with the set up a little but so far so good.
hah! it's always something dumb like that, isn't it? my last stereo work was putting a Delphi XM unit in my mom's camaro. after i finished, nothing worked. i started freaking out, pulling fuses and cheking leads. still nothing.
turns out i ran the battery dead bc i had accidentally turned her headlights on at some point about 3 hours earlier.
Mike
1 - 7 of 7 Posts
