1 - 10 of 10 Posts
Hey guys,
I'm in the process of installing rear camber arms and toe arms on my svt.
I got one side completely done, but I had a seized bolt on the other side
where to toe arms goes. I cut the bolt and now I have a part of the bolt
stuck in the nut, and I can't get it out with any sort of pliers.
I think my two options are to weld the head onto the bolt and that
should allow me to turn the bolt right out.
Or maybe a bolt extraction kit.
I don't have a welder, or a bolt extraction kit, or a drill for the kit.
Any of you guys have a welder and can bring it to my house,
or if you think a bolt extraction kit would work and you have
one that I could borrow, I'd be greatly appreciative.
Here are a few pics of what I'm dealing with:
I appreciate any help or tips you guys can give me.[thumb]
Do you have a torch? You can get some big vice grips and super heat the remaining portion of the bolt to a nice red, start twisting the bolt. Should be easy. I can't come down to help though, I'm in Nebraska till Sunday, sad.
Posted via FF Mobile
PB Blaster FTW. Hit it, let it sit for an hr than try your luck. Worked wonders on my completely seized up e-brake actuator on my zx2.
when I was trying to do the toe arms I had issues with that same bolt...so I sold the toe arms. you should be able to finish cutting it off then just use a locking nut, or probably even a standard nut. I don't think it would go anywhere.
when i installed my air ride kit i had the same exact bolt break off on my car. i ended up getting the cut off wheel and cutting off as much as i could and then hammering through the rest with a center punch.
Got the nut cut off, now i need to drill through the remaining part of the bolt, and then
take my grinding wheel and flatten the side where the nut was a bit, then I'll be
good to install and finally be finished with this project. Thanks for the help guys!
Discussion Starter #9
I ended up getting this finished and it turned out great!
1 - 10 of 10 Posts
