1 - 5 of 5 Posts
ok my cel has been flashing for a couple of days now and I went ahead and used my code scanner and im getting a primary ignition coil circuit malfunction and a cylinder 1 and 4 misfire. heres the kicker replaced coil,spark plugs, and wires and still have the misfire and its getting very irritating im starting to think that my computer may be shot any suggestions
FF's Night Security
It's the plug that plugs into the coil. It's a known and common problem on the early models. The wires get pulled out of the connector. Sometimes you can see the wires, but it breaks inside the plug connector. You need to replace that plug connector and all should be well. [thumb]
Further back in the wire harness that leads to the coil connector would be the next place to look, they tend to get damaged from being too tight or too close to something hot.
1 - 5 of 5 Posts
