1 - 7 of 7 Posts
ok so i took of my front door panels and replaced the speakers w/ better ones. after i put everything back together it started rattling real bad so i took it off again thinking it was the speaker loose well it turns out its the foam crap behind the door panel. is there anyway i can stop it from rattling? thanks 4 any help
It does if its the moisture barrier. You don't want to do that. You may be better off just securing whats makeing the noise some of the foam is just for sound deadning the thick dence stuff is part of the saftey features of your car.
when i was putting the new speakers in i checked all that stuff and i couldnt see were anything was broken it just vibrates alot which makes it rattle i guess. its just really annoying
1 - 7 of 7 Posts
