1 - 11 of 11 Posts
i was driving along, rolled down my drivers window, had a cigarette. now i can't roll it up. not only that but i now don't have wipers, front and rear power windows, sunroof, and my heated seat indicator is very dim. i have a long drive home after the holidays and i need wipers and my window up. please help.
btw the fuses for all said malfunctions seem to be ok. i did however have a blown one for my right lowbeam (harness melted due to luminics bulbs)
FoFo Lover.
Wow...
I would check the relay powering that area.
It's in the same compartment under the hood. I had a relay go after the install of my st170's and my car hasn't been the same since.
FoFo Lover.
hmm....probably not both of them.
Do you have any tools to check the supplying power to each accessory?
Discussion Starter · #5 ·
i have access to a test light. that should work. btw the heated seats are dead too.
pw windows
sunroof
wipers and washer
heated seats
all have separate fuses and relays. is it possible a 40amp fuse went under the hood that supplys power to the pass fuse pannel?
you probly had a short due to the headlight harness melting that caused a major fuse to blow and do a snowball effect. i would start with the fuse/relay panel up against the firewall and check that all out.
Discussion Starter · #8 ·
i hooked up the test light and i'm not getting power to half of the fuses in the pass pannel. seems like 15amp and up. the manuel says there is 2 massive fuses that send power to the pass fuse pannel. if i'm not getting power to the pannel that would mean one of the massive fuses would be blown.
FoFo Lover.
that should be right.... i think those fuses are both 40a.
keep us updated....electrical gremlins are the worst.
thats what i figured. glad you got it solved.
1 - 11 of 11 Posts
