1 - 14 of 14 Posts
hey guys i have a question and i need help. if the brakes and clutch use the same reservoir, can i bleed the clutch through a brake bleeder? as some of you may know, my slave cylinder bleeder is MIA
Someone else more familiar with clutch bleeding needs to reply. My guess is NO... you can not bleed the clutch lines via brake cylinder bleeders. Huh?/Why/How is your clutch bleeder MIA?
No more thing, wtf is a clutch?
Thanks for the reply. I think your right. I was quoted $440 for the slave cylinder. I'll just get it done right
$440 for the part and install????
Same reservoir, but from the master forward, each needs to be bled independently.
That's a fair price given the labor involved.
If I was you I would have a whole clutch kit installed as a while you're there thing.
also its not that hard to remove the transmission and swap this part so you could do it yourself if you was confident.
New clutch went in 9,000 miles ago, so that part should be good.
Oh well yeah then that should be good.
Discussion Starter #13
I'll probably have one put in just in case. I don't want to have it have to come out again in a few months lol
1 - 14 of 14 Posts
