I have a 2000 ford focus se. I just passed 98,000 miles. I have looked everywhere for answers..so I am finally turning to this forum. Here are the issues I am having with the vehicle.
1) The check engine light is on. Code reads misfire in cylinder 2.
I have replaced the spark plugs, wires, coil, o2 sensor (pre catalytic), radiator, had a fuel system cleaning done at a auto shop., Sprayed some throttle body cleaner in it too. Not sure what else I can do to fix this issue, but this check engine light has cause my car to fail inspection.
2) My horn stopped working. It makes a clicking noise, but doesn't sound. So I guess that means the relay is good, but something else is wrong. Not sure what it could be.
3) My heat/ac/defrost stopped working. One day we were driving and my wife shut off the ac and as soon as she did that the ac, heat, defrost did not work any longer. I am not sure what the issue is here either. I don't believe it is the fuse,because I checked them.
All I know is that it is actually dangerous to drive my car when it rains outside and it is foggy outside. I can't see due to windows being fogged up and I can't honk my horn at all the people cutting me off. On top of that the check engine light is on.
I've never had a problem with this car and all of a sudden in the past year..I have had to pour so much money in this car to fix so many issues and they continue to add on. Please give me the best advice and suggestions. I just really want this car to work.
I didn't even mention having to change the shocks and struts, brakes, rotors, tires, and get an allignment, new headlights. Sheesh.** But those issues are in the past.
1 sad sad
Ford owner
1 sad sad
Ford owner
