Hi have had my 2001 Ford Focus for over 2 years now and since then I have had a problem with the car starting.
The issue is that everytime I try to start the car when its been idle over night or even for a few hours its take about 4/5 seconds to start it just turns and then starts, I will notice a smell of gas out side and a fumes smell inside, this will last for a while and then just go. Now after the car has started if I turn of the engine and restart it will start almost instantly. Just to let you know the car has always started in the time I have had it. I live in Cyprus so it is most of the time so it can be due to the cold...
I have been to about 5 mechanics (including ford) however they cannot seem to know the problem. I have changed quite a few bits (spark plugs, filters, checked fule pump, changed the idle contril value (as recomended by one mechanic)...). I read online that it could be due to the air control sensor which I asked one of the mechanis and he said it dont have one its got a MAP system instead.
Even when check on the computer no code or errors come up. So I really dont know what to do next.
Please has someone had or heard of this problem, I could really do with help.
Thank you!!
Thank you!!
